Yep nail on headMr Mister said:i think he is after an x2 because the cold bug isnt as bad as the opterons. He's after a cpu for under phase as far as im aware.
Yep m8 got the Lian li kit to match ma case,phils run out of blue displays so i got to wait a bit to fit it allMr Mister said:when the cpu wont run high htt's when it is sub zero temperature.
Clone you got a new mach 2 gt on order from phil then? Did you go for the black lian li?
Mr Mister said:25C??? what are your symptoms?
