x2 4800+ Temps
17 Mar 2005
London
Hey,
Just installed my 4800+ x2 and just wanted an idea on temps, this is with the stock heatsink on, currently they are running at:
CPU - 45-48
Mobo - 45-46
This this too high? If so what temps should I be looking for?
Cheers
Hey,
To give you and idea, my X2 4400 overclocked to 2.6 temps and completely stable when running two ClimatePrediction.net models all the time are (ie maximum load):
CPU: 46 degC
PWMIC: 58 degC (toasty!)
CHIPSET: 49 degC
That's with a Thermalright XP-90C and a 90mm fan.
My stock X2 4800 watercooled runs between 29-32 idle & 36-38 under load for some water coolage comparison.
Anyone using an ThermalRight SI-120 with the X2 4400? If so whats your temps please, especially overclocks to 2.6hz/2.8ghz if possible.
