X2380HS-B Calibration
13 May 2010
Can anyone advise how to calibrate an IPS Monitor?
Colours look a bit flat and washed out compared to my old LCD, and over-bright despite tweaking the settings both on the monitor, windows calibration, and the nvidia control panel....
Any advice appreciated!
What was your old monitor out of interest?
Restore all the graphics card settings to default, messing around with them on the graphics card will only mess up your contrast and greyscales and make things worse. Ideally you want to only make changes to the monitors OSD. I would suggest restoring the monitor to defaults to start as well.
a 19" Xerox
Can't see an option to reset defaults, the "Reset" Yes/No doesn't seem to do anything...
It's an iiyama if anyone has knowledge of them? Was told they were a top brand!
that option should reset all the monitor settings, unless you're already running at default anyway! change something to something totally random (like 0 brightness), and reset the screen and see if it restores it back to something else :) failing that, check the manual for the screen.
I'd recommend default settings for the screen and definitely for your graphics card/NVIDIA settings before you do anything else.
From there, lower the brightness to whatever is comfortable. that should have no impact on any other aspect of the setup anyway. then try any preset modes on the screen to see if any of them look better to you. you want to only make adjustments to the monitor settings. if non of the preset modes look good, you could enter whatever the custom/user preset mode is, where you should then be able to tweak the RGB levels independently. the tests here might be of help with setting up as well: www.lagom.nl/lcd-test/
like i say, only make changes to the monitor settings dont change brightness, contrast or RGB in graphics card or it will mess it up
if that still doesnt work, get it looking as good as you can from the monitor, then just bump up the "digital vibrance" setting in NVIDIA control panel to boost colours. won't really be "accurate" but will give you more vivid appearance if thats what you're after :)
Thanks,
Managed to sort it, changed to sRGB and colours look fine.
Only issue now, is if i look closely at the screen, on the forums, it looks like the pixels are refreshing? If that makes sense...almost fuzzy on the background?
That's likely to be the Frame Rate Control at work Which is used to provide a 16.7m colour palette from a 6-bit panel.
