X360 and Hitman Problem
31 Jan 2003
Lincoln LN3
Hi ya fellas, ive just been trawling the net to try and find an answer to my problem.
Ive just stuck Hitman in while the missus and son are out and it's come up with the message "This game does not support PAL-50. Please change your setting to PAL-60."
Now ive gone into console settings and im alread on PAL-60 according to the information it gives.
TV is an LG 42" plasma, HDTV settings in the console are 1080 PAL-60.
Kind of at a loss here as to what to do, any ideas?
EXACTLY the same problem I had, and the only way I could fix it was as follows...
Use the standard video lead that came with your Xbox and boot up. Goto the display settings and change the format to 60Hz. Yep, I know it already says it, but do it again.
Remove the leads, plug in your original cables and away you go.
*EDIT* Ahhh, see you've sorted it. :)
