- 8 Oct 2006
Hi all,
I have a 19" Hanns G hw 191dp (widescreen) which i currently use with my PC, it has a dvi and vga in the back (currently use dvi to connect to pc) and have a few questions.
1. I was wondering if i could hook this up with the x360 which i hope to get soon?
2. How good is the quality, and does it fill the whole screen?
3. If It is possbiel, can i easily switch between pc and x360?
4. Anyone have any pictures with x360 on this monitor or something similar?
5. I have 2.1 speaker atm which i connect to my xbox (1) through composite red and white wires. So unsure how i can have sound, if i connect x360 to lcd monitor.
Thanks,
Digi
Thanks,
Digi
, but check out this thread, it may give you some ideas of what people have done:
