X38-DQ6 - upgrade without changing mobo
22 Oct 2002
Currently i have a Q6600 o/ced to 3.1Ghz. I have a 8800GTX o/ced to 600/1000. RAM 2x DDR2TWINX 2GB PC6400C4DHX
What can i realistically put in there to replace those components to see a significant improvment?
improvement in what? gaming? 3D rendering? responsiveness? photoshop? video editing?
each one has it's own set of upgrades. personally, I would get a better GPU for gaming, 4GB RAM for general performance and an SSD for faster loading times.
Purpose determines what upgrade path is best for you. The advice above is spot on.
Post what you want to do and heaps of folks will help you spend your money :)
sorry, you're right: gaming
Mafia II is looking a bit juddery these days.
cloud84: I already have 4Gig RAM. Notice you arent recommending CPU upgrade, what CPU can my mobo take?
i think it is a waste of money to upgrade the CPU for gaming. Do not bother yourself with CPU at all if you only need it for gaming.
Like I said previously, I have a Q6600 @ 3GHz and an i7 @ 4GHz and using a pair of 6870 they perform identically in games.
If you are gaming at decent resolutions then there is no point at all in upgrading the CPU because the bottleneck is the GPU. If you are gaming at low resolutions then a faster CPU will give you more fps but what is the point again if a modern GPU will already give you over 100fps?
it's a nice mobo you got there. throw in a couple of 6870 in crossfire and an SSD and you are all set for another couple of years. I am guessing your mobo can take a Yorkfield CPU with a BIOS update but you gotta double check that with someone who knows for sure. Again, I cannot stress enough how much of a waste would be any money spent on a newer CPU.
