X4 760K HOT
17 May 2017
Newcastle under Lyme
What is a safe temperature i should be aiming for with the X4 760K? It is trying to be cooled with an Alpine 64 GT running at the stock speed of 3.8 and temps of 58-60c.
Assuming that's under load then it sounds fine to me :) If you're just running it at stock speed, you could look at taking a little off the voltage to cool it further.
