x470 ahci driver?
30 Jul 2005
Midlands
got the system setup and installed the amd chipset drivers but noticed its still using the standard microsoft ahci storage driver. my intel setup used its own intel ahci driver, doesnt amd have one? or is standard microsoft one the correct one to use?
According to the link below, you should use the standard Microsoft driver.
If you scroll down to recommendations it is mentioned there:
https://www.amd.com/en/support/kb/faq/pa-250
