- 25 Sep 2012
- Scotland
They probably changed their mind once people start moaning and Nvidia quickly stepped up to try and be the good guy.Oh AMD, you should have maybe anounced older gen support during big Navi fanfare.
If I knew X470 was getting SAM support, I wouldnt have been so quick getting a 3070!
ASUS mentions that they do not recommend the use of this BIOS version if a Ryzen 3000 (Zen 2) or Ryzen 2000/1000 (Zen) or even an A-series processor (Bristol Ridge) is used. Also, and quite important, this BIOS update cannot be undone. Once updated, it is not possible to switch back to an older BIOS version in the event of problems.
Seems like it is 5000 series only. At least you don't need to buy a new mobo.
We look forward to getting the custom of the Italian Stalion back one day!Oh AMD, you should have maybe anounced older gen support during big Navi fanfare.
Using cpu and mb so I'm only getting a semi with Amd just now, maybe get me full on Amd excitement one day.We look forward to getting the custom of the Italian Stalion back one day!![]()
It doesn't say, but considering it specifically states SAM which is an AMD product name it is safe to assume it is only talking about RDNA 2For Nvidia also ? (Yes Nvidia will support SAM at some point - in case anyone tells me it can't be done with Nvidia) Soz can't read link blocked where I am.
Wonder if the performance uplift will be worth be upgrading from B350 to something to take advantage of SAM.
