X52 Pro users
27 Aug 2009
Well i went and splashed out getting a Trackir5 and X52 Pro. Great kit and makes DCS A10 so much easier.
The only issue i have is that the MFD text is all garbled and makes very little sense. Now it says 'Mod1 1 NP Prifile'
Is there any way to fix this as its nex to usless as it is.
Same problems in FSX, garbled MFD.
Yea it's rubbish Saitek drivers really so don't worry.
If you actually display something on it like the FSX radio screen then it works fine.
One thing that will help, is to go to the Saitek DirectOutput entry in your Windows' Services applet and change the startup type to Delayed (or Deferred or whatever setting it is that indicates it'll wait a while for other things to start and then it'll run).
That can fix a few oddities with the MFD as well as your machine BSOD'ing if you unplug the throttle whilst your machine is on.
