X55 controller
6 Nov 2002
Can someone just confirm what's meant to be inside the X55 box when it turns up. Mines just arrived but wasn't sent in any packaging and seems to be open.
So far I have the throttle, joystick, the part the joystick sits on and one different spring in a tube. No CD/documentation? :confused:
X55 should have 4 springs, each different colour. One of those will already be fitted to the joystick giving you the choice of swapping over. Packaging in the box would be moulded cardboard. Of course you should also have a pair of USB leads for the Joystick base and separate throttle.
I can't recall that there was a lot of documentation or any CD. Recommendation is that you go to the Saitek site to download the latest stuff.
