X5650 overclock @4.2
16 Oct 2013
Hello chaps
So all of a sudden my windows clock is going faster than it should like 25% faster the seconds are flying and after a while the clock is 20 mins ahead
Now I've resync with windows online I've even done a command prompt resync but all it does is reset to correct time but the same speed
I've had the cpu 2 years no problem it's been at 4.2 all that time no issues ever now and then it will fail to boot then resets it's self to stock speed all I do then is reapply overclock i have it at auto volts
I am thinking maybe it's the motherboard battery
Anyways sorry for the spam the is for your help
Motherboard battery should only impact anything when the pc is turned off at the wall/PSU.
I'd reset your BIOS, and then see what the clock is doing inside the BIOS menu.
I went into the bios checked the clock and it was fine and it was still overckocked it's just when I load into windows it's fast
I am at work atm I will reset the bios when I get home ty for help
