x570 Master Error Code 8d?
24 Aug 2007
I recently build a new PC (specs in sig). Using the Ryzen Memory Calculator I managed to get a stable OC 3600Mhz on 3200Mhz Dominator Platinum Ram (x4 8GB). However from time to time my PC does not boot just sits at a blank screen and the Mobo error code shows 8d. After a while it reverts back to default settings and boots.
Thing is I've saved a profile, so I re-load it in bios, then after 2-3 more reboots boots fine with OC settings, played games, benchmarks no issues. I have recently updated to latest 1.0.0.4 bios still same issue, anyone have any ideas?
have you manually overclocked your CPU ? also try a little more voltage for your ram - think there's an option for voltage for start up
