- 29 Jul 2021
- Thuirso
I was running bios version 3.80, i downloaded version 4.0 which was the next available so i didnt skip anything, i formatted a usb 8gb drive to FAT32, unzipped the 4.0 bios, moved it to the drive, booted to the bios, went to tools and the instantflash option, it immediately detected the version on the USB drive, i started the update, recived a success message and pressed enter as per the screen instruction to reboot, but the system got stuck at code 91 on the board. i reset the system, same thing code 91. (i dont get anything on the monitor not even a hint that its trying )
I have a 3600x cpu, 4 x 8 gb ram, 6900 xt, all was working prior to flashing the bios.
i have turned the system off, pulled the plug, hit the on button a few times, held in the cmos clear button, booted back up, no difference
what can i do?
what can i do?
