X570 to replace my B450
21 May 2018
South Wales
Need a replacement motherboard to replace my B450 Pro Carbon that I've just gifted over to my daughter, any suggestions on a budget of around £200? It's for a 3600.
Depends on how long is the problem as I'm in need of a replacement asap.
if you follow the thread last ETA was 3rd June so if they get enough stock for all preorder your end next week to be honest
The elite is out of stock, the other is the tough gaming , could ring and ask robbieG what best price on the Bgrade one is My basket at Overclockers UK:
Total: £200.45 (includes shipping: £10.50)​
Not sure of what thread you speak off but the Gigabyte Aorus Elite any good?
Ah right that thread, I will take a peak at the Elite and see if I can find some reviews. How did you get the pre-order data, otherwise I wouldn't mind going for the Tomahawk.
All within that thread mate, RobbieG and the MSI rep have been excellent :), other retailers will get stock of the board but none have it up for preorder yet, if you keep an eye out you might be able to get an order elsewhere , but not everone will do it as preorder
Ah right thanks for the heads up, will keep my eye on the thread and elsewhere in due course.
Curious of the Elite so will take a peak!
@orbitalwalsh - Any info to share on the Elite, any good?
Slightly over budget but if you can wait a little bit the X570 tomahawk
https://forums.overclockers.co.uk/threads/msis-x570-tomahawk-may-become-go-to-oc-board.18884498/
Stock due next week (hopefully) but already 57 preorders on the books so could be a longer wait, or if wifi isn't a massive issue then the Aorus elite is also a good shout
+1 for the MSI Tomahawk, it was the best value board for the overclockers on the b450 platform. Will probably be the same for the b550 and z570.
I was choosing between the Aorus Elite and the Asus Tuf.
Pleased enough with my Asus Tuf so far.
Not sure if I can wait till when said release date for the Tomahawk and torn between the TUF and Elite, both very similar so I guess it's down to price.
Not much in it between them. I reckon the elite is slightly better, but I went for the Tuf as I wanted the extra sata ports.
Aorus Elite is very well balanced for its price and has overkill level VRM to take any coming 16 core Zen3.
Also its chipset cooler is capable to semi passive cooling with good size heatsink.
So X570's bad point of that chipset fan isn't big in it and neither would fan failure cause instantly excessive/overheating level chipset temps.
Asus again uses design from 15 year ago with small heatsink relying on always running fan to keep chipset cool.
The more i look into each of these the Tomahawk maybe worth waiting for after all.
Hopefully retailers get stock next week, or I'll have to pull the trigger on the Elite.
If I was to raise my budget what should I get?
Just came across the the Asrock X570 Extreme4 that's on offer currently, any good when compared to the TUF and Elite.
It's basically the same board as the steel legend I think. It's decent, but unless it's significantly cheaper, I'd pick the Elite or Tuf ahead of it.
I think the TUF is going to be my choice so unless a confirmed release on the Tomahawk is announced anytime now I will be ordering this tomorrow.
Well, I'm certainly pleased with my Tuf. I had a small issue with intermittent video signal on boot though. Flashing the bios fixed that though. Good now.
