X58 Memory question...
17 Jan 2007
I am looking at buying the Asus P6T motherboard.
I currently have a X38 DDR Motherboard with 2 x 1Gb OCZ Platinum DDR3 modules. These are OCZ part number OCZ3P13331G. (OCZ DDR3 PC3-10666 / 1333MHz / Platinum Edition)
My question is, can I just buy one more of these 1Gb modules and then run them as triple-channel?
Seems a waste to ditch the 2Gb I have since they cost so much in the first place, and I don't need 64-bit Vista just yet, so 3Gb will be fine.
Cheers!
Well there was a second hand module going for 26 quid, so I thought stuff it, may as well give it a go...
I normally get my stuff from OCUK, but the prices for the P6T and the i7-920 are a bit over the top compared to elsewhere at the moment - any reason for this? I mean I'm talking about 60 quid more for the 2 than most other places?
I know what you mean, i live in stoke and its easy for me to pop the shop to get my computer gear, but when i looked online for....
I7 920
rampage 2
6gb of corsair dominator
i got all that £85 cheaper than overclockers, i used to buy all my stuff from overclockers but £85 is £85 fine i had to wait a day for delivery, but whats a day
I can answer my own question on this now!
I bought the other 1Gb and it all works just fine in triple channel mode...
Wicked!
