- 12 Apr 2009
Hi all,
Following a recent custom build, my computer with all watercooling apparatus is running perfectly, except for one thing... booting!!!
The MoBo (Gigabyte X58-UD5) takes time to boot up, and after the POST screen, another black screen comes up saying 'verifying DMI pool' and gives a list of PCI devices. As Follows....
I suspected the following to be possible problems:
- The ATX 12V connection on the motherboard is 8pin however I can only connect 4 pins due to the design of the pins from my PSU. I tried converting the 24pin ATX connection to a 20pin also but still no resolve.
- I disconnected and reconnected all hardware
- Haven't got a floppy disk drive connected but I doubt this will make much difference
- get a code on the error display of the MoBo as 'FF' but the manual suggests this is a Boot Attempt and other posts suggest this is a normal message
- perhaps the CPU was a problem but the system picks it up and verifies it and I have used programs such as CPU-Z and Prime95 with these results:
no communication thread? is that a problem??
also, I have 6mb memory RAM installed, the system picks this up but says only 4mb can be used. do these figures seem normal??
any resolutions are welcome guys! need to get this boot thing faster, my main concern is the DMI pool screen with the PCI devices listing....
