X58a - UD3R - Driver
if you are using the ICH you wont need a driver
its only the gigabyte Graid [jmicron or whatever] that needs digitally signed drivers.
For setting up raid he's going to need a driver surely?
Grab the Rapid Storage drivers off Intel's website.
Win 7 has built in driver support for the Intel chipset raid - so shouldn't be a problem, unless of course the op would rather use Intels drivers than Microsofts, but you can always update after the install.
since vista - raid has not needed drivers to set up
enable raid in the bios
CTRL+I on start up
create member disks and set volume type
boot off windows disk
see raid volume in setup
highlight
next
done
Install intelMatrix Storage in windows
it really is that simple
