Im currently doing a bit of overclocking to my x6800, using a IP35Pro motherboard.
Normally i have it running at 3.4Ghz for everyday stuff, but i fancy seeing how high i can get it so i can do some benchmarking.
At the moment i have it running at 3.9Ghz (325 with a multiplier of 12)
The Vcore is at 1.58 at the moment and the Cpu temp is 40'c, with my tunic tower on full tilt.
Now its runs ok until its put under load, i did a quick 1M superPi and got 12.8seconds which im quite happy with. But its not stable on the 3dmark06 and it only does a few tests before shutting down 3dmark.
Do i need to raise any other voltages to make the system stable? The only ones i have touched so far are the vcore and the ram voltage (2.1v for 1050Mhz)
