X6800 Temps....CPU or Cores
29 May 2005
Lads,
what's the average temps that you are having with X6800s ?
Looking in Everest, mine is at the following idle..
Motherboard 43 °C (109 °F)
CPU 31 °C (88 °F)
CPU #1 / Core #1 48 °C (118 °F)
CPU #1 / Core #2 47 °C (117 °F)
GPU 45 °C (113 °F)
GPU Ambient 44 °C (111 °F)
GPU VRM 57 °C (135 °F)
WDC WD1500ADFD-00NLR1 32 °C (90 °F)
WDC WD740GD-00FLA2 29 °C (84 °F)
WDC WD2500KS-00MJB0 29 °C (84 °F)
Do you guys read off the CPU temp or the Core temps ?
This is with a Scythe Ninja with AS5 in a Lian-Li PC-S80. System appears stable so far with 4x1GB DDR2800, but would like to confirm my temps..
Cheers..
Guys,
the above setup..
39000 in 3DMark2001 and 6096 in 3DMark2006 with a HIS1900XT and X6800/ASUS P5W at stock speed can't be right, can it?
CPU friendly 2001 has seen upto 43000 on E6700..
