- 26 Oct 2009
- London
i can set my 3930k very easily to 4.5, with 1.305v and everything else on auto.
boots fine after saving settings, benchmarks all night long with nice cool temps (i have a new, enormous cooling system)
however the next time i try to boot, i usually get an error 00 (i have a rampage gene 4 motherboard) and all i can do is pull the power plug before it will allow me to reboot again.
ive tried setting the startup voltage up to 1.38v but it doesnt seem to make any difference.. any suggestions?
if i cant fix that, the alternative is some windows overclocking software.. however ai suite and intel XTU seem to actually modify the bios, so next time i try to boot, i have the same issues. are there any tweaking apps that let me apply a multiplier change one windows has booted, forgetting it again when i switch off?
iirc the gigabyte software would only apply your overclocking profile while you were in windows ( but didnt actualy work as any changes seemed to crash that machine)
obviously under normal circumstances i wouldnt touch o.c. software with a bargepole, but if it gets the job done...
