X79 OC BUNDLES
11 Dec 2005
Cheshire
Introducing our brand new X79 Overclocked bundles! Featuring the brand new Intel X79 Chipset and the mental Intel Core i7 3960X CPU.
Krypton X79 850i Intel Core i7 3960X 3.30GHz @ 4.40GHz DDR3 Overclocked Bundle @ £1,369.98 inc VAT
Designed by experts the "Krypton X79 850i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton X79 850i" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 16GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s and Intel Ethernet for next gen computing
Bundle Specification
- CPU: Intel Core 3960X 3.30GHz @ 4.40GHz CPU
- Motherboard:Asus P9X79 Intel X79 (default choice)
- RAM: G.Skill RipJawZ 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel
- Cooler: Phantek PH-TC14PE CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £1,369.98 inc VAT.
ORDER NOW
Krypton X79 820i Intel Core i7 3960X 3.30GHz @ 4.40GHz DDR3 Overclocked Bundle @ £1,339.99 inc VAT
- Motherboard: Gigabyte X79-UD3 Intel X79 (default choice)
Service Package
Only £1,339.98 inc VAT.
ORDER NOW
Come on Nath you could have colour coded these a bit better :p
ASUS bundle: blue.
Gigabyte bundle: red/black.
Yeah. Is there any FoxConn boards for X79 on the horizon? Surely it wouldn't brake the CDA. OMG I can't remember what its called not CDA. DMCA? :S CMD.
Would that RAM work on P67 BoardS?
they've got 1 to sell and 'hogging' the rest for their bundles would be my guess, after all more money from these bundles then selling the cooler on it's own.
They've been hogging them for a long time then.
Since they started stocking the Phanteks coolers stock has never shown more than 2 or 3.
