- 19 Nov 2011
Hi all,
A quick question really...
I have a 4930k in a RIVE running at 4.5ghz (101.7 blck) and around 1.42 Vcore on offset voltage.
I have been using HWinfo to monitor CPU temperatures.
The system is cooled by a full loop (1x 360mm, 2x 240mm rads) along with a 980 in the loop. My question is, which CPU temp do I go by?
Core Max is around 29-34c when idle, however, package temp is always 10c higher, so 39-44c.
Which temperature should I be keeping an eye on? If it's package temp then should I drain the loop and replace the TIM, or do those temperature look good?
Many thanks guys.
Many thanks guys.
