x800 GTO
11 Apr 2006
I'm not sure if you read my last posts but to sum up:
I bought a pre built sn26p on ebay
(athlon 3200, 80Gb SATA & ATI x1600 XT)
When it arrived it had a x800 GT installed instead, I got in touch and said I wasn't happy with the swap and we settled on him sending me a brand new sealed x800 GTO in its place.
The only thing is it's the fireblade version and the fan's a bit loud when I'm using the shuttle as a media centre.
I've seen these cards go for ~£100 on ebay. What's the best & quietest card I could get in it's place?
Cheers
Ryan
Isn't the X800GT a better card than the X1600, from what i've read on the graphics card forum the 6 series are utter pap.
I think you got a good deal.
You don't mention if you want to be able to play games on the machine, but i would have thought a passively cooled card would be fine, doesn't need to be high spec and would run quiet as anything.
The deal got better, the x800 GT got swapped for a brand new Sapphire X800GTO Fireblade.
The only thing is it's a bit noisy for my shuttle so I'm thinking of selling it on.
