X800Bravo temps?
2 Oct 2003
Porthcawl (S.Wales)
Ok I'm running this now on its stock cooler, have always ran it on water where max temp never higher than 45c, now it idles at that :p
Whats safe temp for these?
Hitting 70c while gaming for couple mins :(
70's fine I believe, just checking on my X850 now but it's idling at 48 (on a better cooler but running at X850XT speed) :P.
yer tbh cooler that comes with this looks really cheap, running artifact scanner to see what max temp is atm, so far 10mins and its running at 71-72c
That's fine - mine topped out at 73degC on a 3dMark06 test. If you want to replace the cooler then the Arctic is nice ( although some swear by the Zalman ). As you can see the Arctic does a decent enough job given your running a X800 at a slower speed than my 850 and only 2 degree's difference.
ran it half hour an stayed around 71c so all is good.
selling my watercooling off and this card to try n get better one while im skint.
its surprising how much difference water makes on gcard, for me it was a 30c difference in temps :eek:
