X800GTO showing shade of blue
4 Jan 2005
Just installed a Powercolor X800GTO, and at first try, the monitor wouldnt detect it. I took it out and installed again, and now the monitor picks it up, but everything is a shade of blue - why is this?
I use a 485 watt PSU, and my last card was a 6600GT.
A8N Sli deluxe
3200 64 it
2x512mb DDR400
485 enermax psu
sounds like the mon cable isnt completely in or has a pin bent, try pushing both ends back in and check the pins. Using VGA or DVI ?
The cable that goes into the monitor was just a little nudged. I've fitted it firmly in place and it's working now, cheers.
