x850 clocks
29 May 2005
anyone got any clocks for X850 overclocks? been sitting on default XT PE clocks for months now want to see if it can go a lot more, but not patient enuf to go thru the max mem & core process
Mines a really bad clocker on the core, i get 530/610. Havent tried watercooling it yet though, but i cant see it getting more without some sort of voltmod. :)
i got arctic cooler, can hit 570 on core not tried mem, cos last card i borked it by overclocking the mem too much but its sitting happily at 610 right now
quick run started at 570, went to 590 but the temp was 65c i got a bit worried so dropped it back to 540 default....interesting this looks like i cna get a lot more out of the biugger if i went water cooling
640 core what the hell!
My Hightech X850PRO, flashed to 16pipes using XTPE bios does 600/620 on the stock single slot cooler. I run it at 580/600 to be on the safe side (it is in a Shuttle after all :D ).
My x850xt presently runs at 621/596 with an arctice cooler 5. It idles @ 30 degrees C and under load never passes 55 degrees. :cool:
Runs Oblivion really well - never noticeably stutters or slows. All eye kandy turned up with bloom activated and draw distance set to far. :)
Running at 1024 though i think (not sure - could be 1280?) :confused:
Run CCC overclocking suite and see - shouldn't take more than 20 minutes!
gt_junkie
