I haven't tried the X850XTPE bios (should I?) but I'm running at: -
Core - 555
Memory - 570
It works fine and using the ATI Tray Tool's built in 3D renderer it runs without artifacts, and can actually go quite a bit higher than the above before artifacts occur.
But, in TES:Oblivion I get artifacts when running at the above speeds.
Is there anything I can try to get rid of them?
I've also changed the fan settings so it's not overheating or anything.
Thanks.
Core - 555
Memory - 570
Thanks.
