X99 is mental, It runs hot and needs serious cooling to get the most out of it.
If you are dropping £1k+ on a new X99 setup then you really need to be looking at high level CPU cooling options to ensure your new setup is running at its optimium
We have a huge range of coolers already compatible with the new LGA 2011-v3 Socket.
Any Cooler with 2011 compatibility will work fine with an X99 based system.
We have an excellent range of LGA 2011-v3 compatible coolers already but here are the pick of the range for those looking for some guidance:
HIGH PERFORMANCE
Deepcool Lucifer CPU-Cooler - 140mm @ £28.99 inc VAT
Only £28.99 inc VAT.
ORDER NOW
Alpenföhn Brocken 2 CPU Cooler @ £38.99 inc VAT
Only £38.99 inc VAT.
ORDER NOW
Raijintek EreBoss High Performance CPU Cooler @ £29.99 inc VAT
Only £29.99 inc VAT.
ORDER NOW
Prolimatech Megahalems Rev C CPU Cooler @ £42.98 inc VAT
Only £42.98 inc VAT.
ORDER NOW
Corsair Hydro H80i High Performance Liquid CPU Cooler @ £74.99 inc VAT
Only £74.99 inc VAT.
ORDER NOW
ADVANCED PERFORMANCE
OcUK Tech Lab - V8 Watercooling Kit 240
ORDER NOW
Raijintek Tisis Dual Element Extreme CPU Cooler @ £49.99 inc VAT
Only £49.99 inc VAT.
ORDER NOW
Noctua NH-D15 Dual Radiator Quiet CPU Cooler with two NH-A15 Fans @ £77.99 inc VAT
Only £77.99 inc VAT.
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Silver @ £66.98 inc VAT
Only £66.98 inc VAT.
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Black @ £69.98 inc VAT
Only £69.98 inc VAT.
ORDER NOW
Prolimatech Genesis CPU Cooler @ £59.99 inc VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) @ £88.00 inc VAT
Only £88.00 inc VAT.
ORDER NOW
ULTIMATE PERFORMANCE
OcUK Tech Lab - V12 Watercooling Kit 360
ORDER NOW
XSPC RayStorm D5 EX360 WaterCooling Kit @ £262.99 inc VAT
Only £262.99 inc VAT.
ORDER NOW
XSPC RayStorm D5 Photon RX480 V3 WaterCooling Kit @ £323.99 inc VAT
Only £323.99 inc VAT.
ORDER NOW
HIGH PERFORMANCE
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
