** X99 & 2011 CPU COOLING **
rjk
rjk
OcUK Staff
8 Aug 2007
X99 is mental, It runs hot and needs serious cooling to get the most out of it.
If you are dropping £1k+ on a new X99 setup then you really need to be looking at high level CPU cooling options to ensure your new setup is running at its optimium
We have a huge range of coolers already compatible with the new LGA 2011-v3 Socket.
Any Cooler with 2011 compatibility will work fine with an X99 based system.
We have an excellent range of LGA 2011-v3 compatible coolers already but here are the pick of the range for those looking for some guidance:
HIGH PERFORMANCE
Deepcool Lucifer CPU-Cooler - 140mm @ £28.99 inc VAT
Only £28.99 inc VAT.
ORDER NOW
Alpenföhn Brocken 2 CPU Cooler @ £38.99 inc VAT
Only £38.99 inc VAT.
ORDER NOW
Raijintek EreBoss High Performance CPU Cooler @ £29.99 inc VAT
Only £29.99 inc VAT.
ORDER NOW
Prolimatech Megahalems Rev C CPU Cooler @ £42.98 inc VAT
Only £42.98 inc VAT.
ORDER NOW
Corsair Hydro H80i High Performance Liquid CPU Cooler @ £74.99 inc VAT
Only £74.99 inc VAT.
ORDER NOW
ADVANCED PERFORMANCE
OcUK Tech Lab - V8 Watercooling Kit 240
ORDER NOW
Raijintek Tisis Dual Element Extreme CPU Cooler @ £49.99 inc VAT
Only £49.99 inc VAT.
ORDER NOW
Noctua NH-D15 Dual Radiator Quiet CPU Cooler with two NH-A15 Fans @ £77.99 inc VAT
Only £77.99 inc VAT.
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Silver @ £66.98 inc VAT
Only £66.98 inc VAT.
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Black @ £69.98 inc VAT
Only £69.98 inc VAT.
ORDER NOW
Prolimatech Genesis CPU Cooler @ £59.99 inc VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) @ £88.00 inc VAT
Only £88.00 inc VAT.
ORDER NOW
ULTIMATE PERFORMANCE
OcUK Tech Lab - V12 Watercooling Kit 360
ORDER NOW
XSPC RayStorm D5 EX360 WaterCooling Kit @ £262.99 inc VAT
Only £262.99 inc VAT.
ORDER NOW
XSPC RayStorm D5 Photon RX480 V3 WaterCooling Kit @ £323.99 inc VAT
Only £323.99 inc VAT.
ORDER NOW
