X99 Asrock Fatal1ty Issue
19 Mar 2015
Decided to move to the 5820k - and of course the X99.
Issue is this, regardless of voltage when changing the multiplier to 41 it hangs (even in BIOS). Bearing in mind its rock solid at 4Ghz i refuse to accept its a ceiling ive hit.
Any ideas?
for 3000mhz mems are you on 125 strap?? You should be. Use this as a starting point and go from that. 1.25v 4.125ghz. GO!!
