- 21 Jul 2010
Hey,
I was wondering if anyone could critique this build/offer some advice? This is my first watercooled build so I have gone with the bundle. I will be using this system primarily for gaming (games I will be playing: Witcher 3, GTA, Star Citizen). I wont be using any parts from the system I use atm as I am giving it away to family.
KFA2 GeForce GTX 980Ti "Reference Design"
Gigabyte X99-SLI - Intel Core i7 5820K Six Core CPU & Motherboard Bundle
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-19200C14 2400MHz Quad Channel Kit
XFX XTR 850W '80 Plus Gold' Fully Modular Power Supply
XSPC Razor GTX 980 980 Ti VGA Water Block
Microsoft Windows 10 64-Bit DVD - OEM
Seagate SSHD 7200RPM 3.5" 2TB SATA 6Gb/s 64MB Cache - OEM
Samsung 120GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive
OcUK Tech Labs - V12 Watercooling Kit 360 with XSPC X20 dual Bayres/pump, Magicool copper radiator III PRO-360 mm, Mayhems X1 clear premixed watercooling fluid and primochill promoflex advanced tubing 16/11 black.
XSPC Razor GTX 980 980 Ti Backplate
Fractal Design Define R5 Midi Tower Case
Total is £1762
First question I have is what is a good watercooling case for a 1st time watercooled build. I like plain cases, the case I have atm is a Bitfenix Shinobi mid tower. However, I think it would be a bit snug. Im not too fussed about flashy cases, personally prefer a cheaper case. Ive got a £100 max to put into the case.
Second question, ive gone for a watercooling bundle, is it cheaper to buy parts individually, if so what parts do you guys recommend? Also if I did go with the bundle is there enough tubing to add in a vga block as well?
Third question, I havent kept up with computer components that much since my last build. Is there anywhere where I can shave off the price a bit on this build getting down to £1500 would be ace as I need to buy a new monitor in the coming months? I am only looking to do a bit of overclocking? I was wondering if I was better off going with the new skylake i5 if I am only gaming on this system?
Cheers for the help
Total is £1762
Cheers for the help
