Well, I hope to do a build log. The following will be arriving soon, will be using existing GPU (Titan X), PSU (AX860i) and drives (too many to mention). Leaving lighting and cable mods but I want to see how the build works out before ordering them. Here's the order list -
Intel i7-5930K 3.50GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75930K) £379.99 1 £379.99
Asus X99 Deluxe/USB3.1 Intel X99 (Socket 2011) DDR4 ATX Motherboard £262.49 1 £262.49
Corsair Dominator Platinum 32GB (4x8GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit (CMD32GX4M4A2666C15) £241.66 2 £483.32
Phanteks Enthoo Primo Full Tower - Black/White £166.66 1 £166.66
Aqua Computer Aquaero 6 XT USB Fan Controller £108.32 1 £108.32
Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV256HDGL-00000) £99.99 1 £99.99
Coolgate CG480 480mm Radiator - Black £73.29 1 £73.29
EK Water Blocks EK-XTOP Revo D5 PWM - Plexi (incl. pump) £67.49 1 £67.49
Coolgate CG280 280mm Radiator - Black £49.99 1 £49.99
Watercool Heatkiller IV Pro Intel - Acrylic Clear £41.66 1 £41.66
Aqua Computer Aqualis Eco 450ml £37.49 1 £37.49
Monsoon 16/10mm (ID 3/8 OD 5/8) Free Center Compression Fitting Six Pack - Chrome £20.79 2 £41.58
Monsoon 16/10mm (ID 3/8 OD 5/8) Free Center Compression Fitting Six Pack - Matte Black £20.79 2 £41.58
Mayhems Blitz Pro Cleaning System £20.79 1 £20.79
Mayhems Pastel - Ice White Coolant 1L £12.49 3 £37.47
Koolance QD3 Female Quick Disconnect No-Spill Coupling, Compression for 10mm x 16mm (3/8in x 5/8in) £10.79 1 £10.79
Koolance QD3 No-Spill Quick Release, Bulkhead Male, 1/4 inch £8.74 1 £8.74
XSPC LCD Temperature Sensor (White) V2 + G1/4" Inline Sensor £7.49 1 £7.49
Monsoon 16/10mm (OD 5/8) Rotary 90 - Matte Black £7.24 2 £14.48
Monsoon 16/10mm (OD 5/8) Rotary 90 - Chrome £7.24 2 £14.48
Monsoon 16/10mm (OD 5/8) Rotary 45 - Matte Black £7.24 2 £14.48
Monsoon 16/10mm (OD 5/8) Rotary 45 - Chrome £7.24 2 £14.48
ModMyMachine Shoggy Sandwich V2 for Pump Decoupling - Black £5.79 1 £5.79
Monsoon Premium G 1 / 4 Temp Plug - Matte Black £5.41 1 £5.41
XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Clear £5.41 2 £10.82
Monsoon Premium G 1 / 4 Temp Plug - Chrome £5.41 1 £5.41
