X99 ddr4
7 Jan 2010
Up NORTH
I'm confused as it's saying this new ddr 4 will fit in mobos with less than 288 pins?
The x99will support low voltage (1.2V) DDR4 RAM kits (must be the 1333 MHz ones). The DIMM connector now has 288 pins (as opposed to 284 from earlier), the 4 additional pins added to support NVDIMM modules. Good news is that both 284/288 pin RAM modules will be usable on motherboards with the 284 pin connector or the new 288 pin connector. It will have 14 USB ports and 10 Sata ports. Interestingly it will also feature Intel’s Integrated Clock Support.
X99
