***FINISHED BUILD IN POST #14***
I had planned to do this as one build but I had a delay with the case so I put it in an old case to begin with, and now I'm going to rebuild it with the new case tonight!
Parts:
Xigmatek Case (don't know which one)
Intel 5820k
EVGA X99 Micro ATX
Crucial DDR4 2133MHz
Palit SuperJetstream GTX 980
Corsair H55
Superflower Golden Green 650W
Seagate 600 Series 480GB SSD
1TB HDD
DVDRW Drive
Parts at home waiting for me tonight:
Fractal Design Arc Mni R2
2x SP120 Performance Fans
The computer will be for gaming and for 3D/Game Engine work, so I'm very excited about the 6 cores
Pictures of how it's looking at the moment:
Cable routing in this thing is a nightmare so this is the best I could manage I'm afraid.
More Pictures to come of the finished build in the new case...
My thoughts so far...
The Xigmatek case I have is pretty awful. The tool less mounting mechanisms are horrible to use, some have broken, they are flimsy and...orange..?
The power supply - generally fine, quite nice and compact, only downside is the lack of decent cable braiding. A thicker braid would be preferable so that I cant see through it, and the ends of the cables aren't braided/heat shrunk which spoils the look a bit. I will likely buy some braided extensions to hide this.
Motherboard - All seems fine, nice build quality with a minimalistic clean look. The UFEI BIOS is something completely new to me, but I think it's great, very easy to use. On board power, reset and CMOS clear is a nice addition.
RAM - it's....ram.
H55 - Nice and easy to install, seems well built - I'm getting mid 20's on idle. Will test it properly with he new fans in the new rig. I'm going to mount this at the front so it's sucking cool air in.
Graphics card - I'm pretty blown away with this, its completely silent on idle (no fans even on) and even at high load (BF4 1080p Max Settings) its nice and quiet. It's a very nice build quality too, the red metal casing is nice and feels solid.
Looking forward to putting it in its new home tonight!
Parts:
Intel 5820k
EVGA X99 Micro ATX
Corsair H55
1TB HDD
DVDRW Drive
RAM - it's....ram.
You can see it in the pic below, it's not that noticeable but I notice it...
