X99-S DPC Latency issues and Stuttering under load.
What is it affecting directly? - I can't say I understand exactly what's causing the higher latency, but what are you noticing outside of benchmarks to be stuttering?
Does the board have two Sata controllers? If it does try using a port that runs off the other controller until a better driver is out.
Tried the other SATA controller to no luck. A re-install results in the same results (with the default fresh install drivers)
My SSD is an OCZ Vector running V3.0 Firmware.
Try updating the audio, NIC, etc drivers.
Also if you have the HPET enabled in the BIOS, disable it.
All drivers are up to date and I've even tried a plain windows installation on a different SSD with no drivers and get the same results.
HPET isn't supported on this X99 board.
If you have an X99, what do you get in regards to DPC latency when doing a QD 4K-32 Read / Write in CrystalDiskInfo?
