x99 sabertooth build with weird O/C fail and no boot
15 Dec 2008
Hi all,
I have a strange issue with my X99 build. I run a mild overclock of 4ghz, bump the CPU voltage upto 1.25v and use the XMP profile for my memory. 99% of the time it runs fine and would run all day every day if i let it.
On occasion I get a overclock failed on boot....but only if I have a long day out and the PC has been off a long time. So I go into BIOS and reload the current O/C profile and reboot again, same msg again. If I load defaults and boot I get further sometimes but sometimes I get no display after the windows load icon. I end up taking the case off and playing around removing DIMM modules / swapping gfx etc and suddenly one time it just works again.
The kit I bought is pretty decent and its only done it 2-3 times in a years time but I'm wondering if it's a capacitor issue on the PSU/board. I think the sabertooths are tested quite thoroughly so I'm more thinking PSU?
Asus TUF X99 Sabertooth Intel X99 (Socket 2011) DDR4 ATX Motherboard
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-19200C14 2400MHz Quad Channel Kit - Black (CMK16GX4M4A2400C1
Intel i7-5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75820K)
Fractal Design Define S Midi Tower Case - Black Window
Noctua NH-D15S Dual Radiator Quiet CPU Cooler
Super Flower Leadex Platinum 750W Fully Modular "80 Plus Platinum" Power Supply - Black
Noctua NF-A14 PWM Fan - 140mm
MSI GTX970
120gb / 500gb Samsung Evo SSD's
Cheers
