X99 Spec Check/Reccomendation
9 Dec 2006
@ManCave
So the Titan Black could be a placeholder depending on the 880 Annoucements:
Are their any other cases, that hide PSU's & give ton of cable space?
I Choose the 5930 Just incase i want 3 GPu's ;)
Is their Anything i missed to add to basket? (got O/S)
YOUR BASKET
1 x MSI GeForce TITAN Black Edition 6144MB GDDR5 PCI-Express Graphics Card £655.99
1 x Intel 5930K 3.50GHz (Haswell-E) Socket LGA2011-V3 Processor - OEM (CM8064801548338) £429.95
1 x Asus X99-Deluxe Intel X99 (Socket 2011) DDR4 ATX Motherboard £295.99
1 x Crucial Ballistix Elite 16GB (4x4GB) DDR4 PC4-21300C15 2666MHz Quad Channel Kit £239.99
1 x SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply - Black £137.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Arctic White (CC-9011048-WW) £104.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £99.95
1 x Noctua NH-U14S Ultra-Quiet Slim CPU Cooler with NF-A15 Fan £62.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £59.99
1 x Silverstone Cable Extension Value Bundle - White £10.80
- 1 x Silverstone 6-pin 25cm PCIe extension - White £4.26
- 1 x No Second VGA Cable Required £0.00
- 1 x No Molex to SATA Adapter Required £0.00
Total : £2,116.38 (includes shipping : £11.25).
2 SSDs because the 1 for OS 1 For Gaming :) I got tons of 3TB HDD's already :)
got opening post wrong wanted the dexule :)
gaming i know i dont need 6 cores but upgrading from a i7 3770k, kinda pointless but hell of fun :D
The Titan Black is kinda pointless as well :) A 780ti would be a better option for gaming, if you want to stick with Nvidia.
Also you don't need a 1300W psu. A good 850W is plenty for SLI.
If you don't intend on going 3 way sli then you could drop down to the 5820K. The only difference as far as i know is the pci-e lane bandwidth, and slightly higher clock speed.
I think you are mad upgrading from a 3770k though :p
true just want somthing new, but titan is placeholder for new 880s.
i want the choice of tri sli this why i went with 5930
Personally if you've only a single GPU I'd ditch the 5930k and go with a 5820k instead. That or push the boat out and go for a 5960X.
Edit just noticed you comment about multiple GPUs...... 5960X would warrant an additional £300 if you're spending £2000+ and planning SLI later down the line IMO!
