X99 Sweet Spot? (side-Grade)
9 Dec 2006
@ManCave
Before you Go You don't need to upgrade. I Know. But want to :D
however please help me with spec
I'm going to rip stuff out of the old computer
Current Spec
i7 3770k @ 4.4Ghz
MSI Mpower Z77
16GB 1600mhz
128GB SSD x3
3TB
2x 980GTX
HX850W
i'm Thinking
YOUR BASKET
1 x Intel 5930K 3.50GHz (Haswell-E) Socket LGA2011-V3 Processor - OEM (CM8064801548338) £429.95
1 x Corsair Vengeance 16GB (4x4GB) DDR4 PC4-21300C16 2666MHz Quad Channel Kit - Black (CMK16GX4M4A2666C16) £239.99
1 x Asus X99-S Intel X99 (Socket 2011) DDR4 ATX Motherboard £235.99
1 x SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply - Black £149.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £59.99
Total : £1,125.50 (includes shipping : £8.00).
2x 980GTX
Move SSD over
Move 3TB Over
What heat-sink do you think would be good? Air please.
would you change much? if anything
750D but i will not being using it.
Will keep the current build in the 750D
not sure what to grab for new one, if you could suggest some be good.
I cant think of any other cases, cannot see why you would want to change from a 750D to be honest.
As for heatsinks you will want something massive,
YOUR BASKET
1 x Noctua NH-D15 Dual Radiator Quiet CPU Cooler with two NH-A15 Fans £72.90
1 x Phanteks PH-TC14PE CPU Cooler - Black £69.98
1 x Silverstone Heligon SST-HE01 CPU Cooler £44.99
Total : £197.47 (includes shipping : £8.00).
the Noctua fits the X99 Deluxe and X99-A - http://www.noctua.at/main.php?show=compatibility_gen&products_id=68&lng=en#LGA2011-3_Asus and they look the same as the one you want.
funny enough i have the phankteks atm but it bugs me as cant get to ram however noctua should be able to
sent you a trust also
Will you even need that high spec a psu? Im running 2x 980s and a 4790k currently of 850w as well and thats plenty!
thinking going quad ;) sop like a bit more juice in the tank
but 120 is just for os but might just bump it to a 500GB
As for the air cooler, i feel its a bit of a shame having a HUGELY Overclockable CPU but not having the cooler to allow it. You won't go far with that noctua. That cooler is designed for silence not sheer performance. The way to get a Big OC and access to RAM is by getting a AIO/CLC (or watercooling). Otherwise get a TC14PE or D14/D15 and just live with not being able to get to your RAM.
well the noctua i linked has been used by jayfrom Asus got 4.5ghz on a 5930k with good temp at load (youtube videos) thought it would be good enough
might reconsider soon loking at case alternatives from 750D atm
am i missing anything? seem like i am? (dont need case or os)
