XBMC and menus.
15 Mar 2010
Bucks
Help!
Iv used XBMC for quite a long time now, no problems at all. I see Aeon has a 3.0 release now and have been playing around with it before putting on the HTPC properly.
Im struggling to fill new menu items with movies. So normally for tv shows and movies you go to videos select the folders and type and it scans/autofills - which is all fine, so how on earth do you fill music vids (now called concerts) and also i want a menu called 3D which i have made but how do I allocate a folder to it?
do i need to go into the scripts or can it be done via menus??
