XBMC Library Mode Problems
28 May 2010
London, UK
how to permanently disable library mode in xbmc?
I have installed XBMC10 in my pc and added a folder which has DVD movies and some TV shows, each movie or TV show is in a separate folder. But my problem is, when I ran xbmc I always have to set the library mode off every time.
With the library mode on I cant see the tv shows, I can only see the movies.
Help please:confused:
If you aren't using library mode, then you're doing it wrong :D
As above, TV shows will be in the TV Show section which you may need to enable in the skin settings.
Ahhh ok I have not labelled them as TV shows yet. They are all in one parent folder called Movies. Gona give it a try later, thanx
