XBMC NFS Help...
7 Jun 2005
North East
Just installed an Asus N66U router and now have my Virgin Superhub 2.0 set to modem mode only. This all works.
I also have a MyBookLive 3TB NAS connected, which is cat5e wired to an XBMC box in my living room. It was previously working just fine using NFS mode.
Since installing the Asus N66U, everytime I go to add a source in XBMC, it just hangs and stops responding. I believe I have an issue somewhere.
Now, it's important to note that I have my MyBookLive set up with a static IP, as many of you will know this helps maintain consistent library for XBMC.
The fault will likely lie amongst this lot - spot any issues?
MyBookLive Static IP Settings
IP Address: 192.168.1.46
Netmask: 255.255.255.0
Gateway: 192.168.1.1
DNS Sever: 192.168.1.1
Asus N66U
Lan IP: 192.168.1.1
Subnet Mask: 255.255.255.0
Allocated a fixed IP slot in Asus N66U for MyBookLive under 192.168.1.46
Ah screw it guys, can't be arsed messing around. I've gone back to Superhub, everything works fine, the N66 is getting returned. Hate networking related issues, it's all just voodoo to me.
