XBMC Scraper (TMDB) not finding 300 Rise of and Empire
19 Oct 2002
Swindoniantown
Trying to add 300 Rise of and Empire to XBMC, but no matter what combination of title I use for the file (looking at the options on TMDB) but the Scraper, which is also TMDB doesn't seem to find the movie and add it!!
Anyone know what it's supposed to be called so it will be found and added!!?? :)
One of the reasons why I switched to Plex from XMBC. I think you can create a movie.nfo file with an imdb link to the film inside, if you put your movies in separate folders. If your movies are all in one folder, name the .nfo the same as the movie file.
P.s. Plex found it first time :-)
Is the file correctly named? As title should be 300 Rise of an Empire
Fat Fingers on the Thread Title :D
I got it to load manually, added the file within XBMC myself, and just said it was 300 to see the list, I scrolled down to '300: Rise of an Empire' and selected it!
I had this problem trying to sync my Sherlock Holmes writes via TVDB. Turns out for some inexplicable reason, they name it Sherlock Holmes (1984) on TVDB, so I had to change it.
Cool story yeah?
'Steven Kings The Stand' seems to think it's some weird documentary hosted by David Suchet! I had to sort that one manually too!!
It has in the USA.
I pre-ordered the special twin box set about 2 months ago and it turned up last Friday!
It has in the USA.
I usually wouldn't post in a thread like this but read that and....REALLY?!? :p:D:rolleyes:
Pics of the box with Hovis I believe is required? :D
