13 Jul 2007 at 18:05 #1 brakeinup brakeinup Associate Joined 6 Jan 2006 Posts 1,061 Location Notts/Derby Is it possible to replace an XBOX internal hard drive with another original drive that has been pulled from another XBOX (not 360)? Is it as simple as a straight swap? Cheers
13 Jul 2007 at 18:11 #2 Armadillo Armadillo Soldato Joined 29 Feb 2004 Posts 3,999 No not a straight swap. The harddrives are locked to the xbox they came from , you'd have to lock it to the new box before it would work.
13 Jul 2007 at 18:15 #3 MouseMat2004 MouseMat2004 Soldato Joined 16 Jan 2004 Posts 2,662 Location Workgroup Effectively you'd have to mod the Xbox, do the stuff*, then unmod it again. *Theres a few ways but both will require extra hardware and software. Pretty simply job if you know what your doing though.
13 Jul 2007 at 18:17 #4 brakeinup brakeinup Associate OP Joined 6 Jan 2006 Posts 1,061 Location Notts/Derby Ahh ok - thanks for the replies
