Xbox 360 5.1 Speakers
Don
20 Feb 2006
Leeds
Hi,
Anyone got any suggestions for a good 5.1 set of speakers that will work with my 360,Cheaper the better don`t need anything flash :)
Thanks
Stanners said:
Hi,
Thanks
depends on you budget mate. 300 - 400 quid should get you a decent small AV box set. However, i always prefer seperate system that is how i end up with the one i am using now.
Could try either the Logitech Z-5400 or Z-5500, the former can be had for £150 inc. delivery if you know where to look. I have no experience of using these for a console though, its just a suggestion.
For a console i wouldnt spend much tbh... games dont really have depth or quality to the sound in general...
Logitech S500 for around £50 or the Z5400 for £130 would be my choices...
spending more than that on PC speakers is silly tbh :)
