Thought I'd start a little thread where we could keep useful info on the 360's AV connections/functions/settings/whatever as similar questions seem to come up pretty frequently - hopefully this will help somebody somewhere
Here is a little to get the thread started, any incorrect info please say! Please help and add anything you can
Jargon:
SD - Standard Definition (wikipedia link)
HD - High Definition (wikipedia link)
Scart - Analog SD AV interface (wikipedia link)
Component - Analog video interface, usually associated with HD (wikipedia link)
VGA - Initially a computer video interface, now present on many HDTVs (wikipedia link)
Optical Audio - Sometimes called 'toslink', a fibre-optic sound interface able to carry digital audio (wikipedia link)
Phono (RCA) - The typical AV connection that everyone will have seen at some point! (wikipedia link)
PAL - Video colour encoding standard we follow in the UK (wikipedia link)
Upscaling - A method of resizing a video signal usually associated with SD sources on HD displays (wikipedia link)
Available AV cables:
Note that this list only contains 'official' microsoft cables, there may be others available from 3rd parties but it is generally agreed that the microsoft cables are less likely to give problems and are therefore recommended (lots of 3rd party VGA/component cables gave ghosted, blurry images).
"Composite AV Cable"
Included with core system
RRP £?
NON-HD
The most basic of all available AV cables. Included with core systems, this cable is really only intended for use on SD TV sets or as a basic starter in order to get you up and running. If your TV can accept a HD input or has RGB scart connections, it is strongly suggested you replace this cable with a superior one.
This lead is supplied with a scart adaptor (still a composite signal, do not confuse with a true RGB scart such as the "Advanced Scart AV Cable")
Pros
+ Can be used with pretty much any TV set made within the last 15 years
+ Extenders can be attached to the two phono/RCA connectors for routing to seperate audio equipment (Hifi etc)
Cons
- Far inferior picture quality when compared to RGB Scart / Component / VGA cables
- No digital optical audio output
RRP £17.99
NON-HD
A step up from the Composite AV cable, but still intended mainly for SD sets due to its inability to offer HD video. This cable provides a true RGB picture which is a far cleaner & sharper image than that provided by composite.
Pros
+ Sharper, clearer image than composite
+ 5.1 Dolby Digital optical audio output (and standard stereo too)
Cons
- Inferior picture quality to component or VGA
- No phono/RCA connections, so no easy way of outputting audio to a seperate source if you do not have a digital connection on your audio equipment
"Component HD AV Cable"
RRP £19.99 (Included in box with premium system)
HD
This is probably the cable 90% of people with HDTVs will have, mainly as component is available on all 'HD Ready' HDTVs, and because it is included with the premium pack. Able to offer a great HD picture right up to 1080p and 5.1 Dolby Digital surround sound via the optical connector.
Available video outputs:
480p
720p
1080i
1080p
Pros
+ Able to provide true HD video
+ Switchable between component and composite, ideal if you use more than one TV and one of them is SD only.
+ Extenders can be attached to the two phono/RCA connectors for routing to seperate audio equipment without optical inputs (Hifi etc)
Cons
- Not quite as sharp picture as VGA on most TV sets
- Optical audio cable not included
- Does not allow for upscaling of DVDs
"VGA HD AV Cable"
RRP £19.99
HD
A superb cable for those that either have a HDTV with VGA(PC) input, or those that wish to use their standard computer monitor as a HD display for their 360.
Available resolutions:
640x480
848x480
1024x768
1280x720
1280x768
1280x1024
1360x768
1920x1080
Pros
+ Use your computer monitor as a HD display for the 360!
+ Allows for upscaling of DVDs
+ Phono/RCA to 3.5mm headphone-type jack adapter supplied for connection to 3.5mm audio sockets (useful for such connections as computer sound cards 'line in')
Cons
- On some TV sets the colours are not quite as vivid as those displayed when using the component connection
FAQs
Should I use 720p or 1080i?
A new topic on this question is started pretty much weekly in the OCUK Console forums. There is only one true answer: Whichever looks best on your TV. Try them both for a few hours and see which you prefer!
Jargon:
RRP £?
NON-HD
Pros
Cons
RRP £17.99
NON-HD
Pros
Cons
HD
480p
720p
1080i
1080p
Pros
Cons
"VGA HD AV Cable"
RRP £19.99
HD
640x480
848x480
1024x768
1280x720
1280x768
1280x1024
1360x768
1920x1080
Pros
Cons
FAQs
