if i connected my xbox360 to this
http://www.overclockers.co.uk/showproduct.php?prodid=MO-005-BE
would it play in HD
would it play in HD
DJB said:thanx for the speedy reply
would i need a HD => to DVI cable for this ?
from the back of my xbox
Quick question here, my HDTV does a maximum of 1440x900 on VGA, but can do 1920x1080 on other devices, any particular reason for this? It can display 1920x1080 on Windows, but it can't fit it all on the screen, bit odd. Same thing for 1650x1050 (Or whatever that res is)Johanson said:Correct, except the is no 720i, only 720p.
HDTV resolutions: 720p, 1080i, 1080p
That 19" monitor has a resoltuion of 1440 x 900, so is capable of displaying 720p (1280 x 720), but not capable of 1080i/p (1920 x 1080). However 1080p would be pointless on a 19" screen, but 720p will look great!
Mr_White said:Excellent monitor, mine recently arrived as well, it's for nothing but my 360, and looks awesome.
But one thing, do your self a favour and buy the official MS VGA lead.
but the cab;es won't go into my PC speakers?DJB said:which one.the belinea or the Lg mon ?
Disco_stoo said:Silly question, but what sort of speaker set up do you need to use the audio cables on the Xbox VGA cable? I've got a 19" monitor (not widescreen though but the cab;es won't go into my PC speakers?
