Xbox 360 controller on PC.
26 Dec 2005
Paisley
Is there any other software you can use for the 360 pad?
I have fahrenheit, for some reason it wont let me re-assign the buttons, and you need to use both sticks with it, im sure i heard someone had used an alternative driver set or something.
Any ideas guys?
I use Pinnacle Game Profiler, it's pretty good. Theres another one out there but I can't for the life of me remember the name :/
Does XBCD allow the triggers to be mapped in games that don't usually support them? (ie. most games don't recognise the triggers when you try to map them)
I think so. The XBCD drivers also come with a Setup utility that let you set the buttons.
MarcLister said:
Not sure. Don't think so tbh. Mate of mine said no I think.
Did find this though. http://www.google.co.uk/search?source=ig&hl=en&q=xbcd +wireless&meta=
I just found on there website the following :(
Warning!!
These Drivers DO NOT currently work with the wireless controller. Please email me to be added to the list so you can be notified when these drivers are of use to you. However you can go to the download page and download xpadder to keep you going for the time being.
http://xbcd360guide.50webs.com/guide.html
