Xbox 360 controller, toggles to sensitive.
14 Apr 2011
Newark
I can`t for the life of me get to grips with the toggles on my wireless controller, they are just to sensitive for me. Is there anyway i can adjust the sensitivity, to sort of stiffen them up.
When you say toggle, do you mean the thumbsticks? Or the triggers?
Most games will have a sensitivity setting within the game itself.
Yes mate , the thumbsticks.
The only game i have is GoW2. Tried all the settings and it does`nt make any difference. Takes to long to line up crosshair with target. Would like to get more games, as i like to play xbox on the TV. So at the moment it`s been sat there for the last 18 months gathering dust.
You could try FPS Freeks. They are little extensions for the thumbsticks. I tried them out on CoD and it improved my aim and I found them much easier to use.
Seen them, but they advertise "Higher sensitivities mean superior kill rates" .
I want less, so when i move the thumbstick, i am not veering all over the place. If the thumbsticks where a bit stiffer, like my old PS1 controller, that would be perfect.
