XBOX 360 Display Input Help
16 Apr 2007
UK
Hey all,
I got an Xbox 360 but the "Component In" on my TV (Blue, Green, Red) isn't working anymore - So I'm having to use the "AV 3" port (Red, Yellow, White) for now, but it's not HD...
I want to get HD back - SD just isn't cutting it :p How can I do this? I do have some spare HDMI ports - Is there such a cable for the 360 with a HDMI male end?
Thanks,
Marky
Hey all,
Thanks,
Marky
Guessing this is an old Xbox pre-HDMI port then?
Got a VGA input on your TV? Sounds like that would be the best way to go for you. :)
If you do go VGA try to get an official cable, there's lots of problems with some (not all) third party cables.
